Beocord 8004 - high level and distorted recording on the left channel
Rammie16
Posts 5
Rammie16 Posted: Sun, Aug 11 2019 9:14 AM
Beocord 8004 - mechanically working fine and playback fine with previously recorded tapes but when recording the left channel is nearly in the red at 0 on the left slider and is distorted at anything above.
Right channel recording working perfectly. Any thoughts please?
Thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Aug 11 2019 12:44 PM
If your deck has the level switch at the rear, check that it is working.
Give it a shot of contact cleaner and work it a couple of times.
Rammie16
Posts 5
Rammie16 replied on Mon, Aug 12 2019 7:23 PM
Thanks Martin, that was my first thought as it sounded as though the distorting channel was stuck in the DIN setting.
Unfortunately my 8004 doesn't have the line/DIN switch on the rear - so does that mean that my 8004 is supposed to auto switch between the two inputs and if so what could be faulty?
Just wondering if I can record from the front DIN as a workaround.
Sorry for so many questions!
Dillen
Posts 13,191
Dillen replied on Tue, Aug 13 2019 6:58 AM
The switch at the back (right next to the DIN socket) is a level switch, not an input switch.
The OpAmps are known to failure, it could be one of them - there's many.
Else check capacitors and trimmers. Capacitors age and trimmers fall apart from oxidation.
A scope comparing the signal paths would help a lot.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
