Beovision 5 won't power on after power cut
Graham1982
Posts 29
Graham1982 Posted: Tue, Aug 13 2019 3:33 PM
Dear all:
Please note I am not in-front of the unit and won't be until the weekend so I am unsure what the issue is at the moment.
All I know is that the TV will not switch back on. Is there a common/easy thing to look into - perhaps a fuse or something?
Graham
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Aug 13 2019 8:49 PM
The BV5 is as hard as nails. It's not far off an Avant CRT with a Plasma screen in it...
The first thing I'd check is the fuse in the plug. Smile
Graham1982
Posts 29
Hi Lee:
Turns out despite disabling the pin code feature, the power cut reinstated it. Quick call to B & O and master code provided.
Graham
Page 1 of 1 (3 items) | RSS
