hi guys, i have my beosystem 4500 set up at last but am waiting to source some CX50 speakers and also the opportunity to get them out here to Thailand, i will need to pick up some speakers in the meantime so i can enjoy my set up, not too expensive because they will hopefully on;y be in use a few months
what do i need to be aware of when purchasing new, ohm rating? watts per channel? any other pitfalls?
any guidance appreciated, cheers
how much you want to spend? Inclusive/exclusive postage, new/used?
Kind regards,
Rolf
Almost anything you like is the answer. 4 to 8 ohm and able to take about 50W or more would be ideal.
Peter
thanks peter, all i needed to know, will pick something up locally as soon as i can, only using headphones so a treat is in store
