CD Hub for Beocenter 9000
Remidiah
Posts 1
Remidiah Posted: Thu, Aug 29 2019 5:09 PM
35 years ago I bought my beocenter 9000, its still in daily use and brilliant.
BUT the central locating hub of the CD deck is missing. This is the plastic bit surrounded by a spring.
I know they stopped supporting this one yet does anyone have one I can use/buy? I am hopeful its the same part as used on other decks?
My (almost) retired B&O engineer has said the option is to buy a DVD player and plug it in via DIN as an aux or Tape 2 yet  I would prefer to use the existing deck if possible?
Remidiah
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Unfortunately this part is unique to the Beocenter 9000, however, some years ago it was being 3D printed by a fellow member of ours.
Search the forum and you will eventually find a reference.
Found it....  https://archivedforum2.beoworld.org/forums/p/6412/57460.aspx#57460
Regards Graham
Beobuddy
Utrecht, The Netherlands
Posts 3,972
PagesHiFi
Posts 2
PagesHiFi replied on Tue, Dec 17 2019 5:10 PM
Hi there - i desperately need one of these hubs for my 9000 - a heavy-handed child changed a CD and the hub / cap and spring went flying!
PagesHiFi
Posts 2
Page 1 of 1 (5 items) | RSS
