Dear members,
version 8.3 upwards preferred. I'm in need of the IC. Thanks!
Kai
Hi Kai,
the content of the chip or the chip itself?
I have the version 10.2 vor the Avant 32 RF DVD/ BV 3-32.
Can you burn an EPROM if i send you the file?
Ralph-Marcus
Thanks very much for the answer. I'd very much prefer the chip itself since I'm lacking ability to burn an EPROM myself. I am not even sure whether it is the EPROM that causes worry. But I'd like to give it a try! Thanks again! Kai
Ok, i can burn an EPROM and send it to you. Cost will be just for the postage.
But i doubt that it will help much for your problem because the TV itself works, just shuts down at random times..
Send me a PM if you still want the chip with the 10.2 Software.
