Correct cable to connect a new CD player to the Beomaster 5500
This post has 3 Replies | 2 Followers
princetonnj
Posts 2
princetonnj Posted: Thu, Dec 6 2012 6:50 AM
I am buying a new CD player to replace a Bang and Olufsen CD 50 CD player that was connected to a Bang and Olufsen Beomaster 5500 tuner/amplifier.
The B&O CD player was connected to the Beomaster 5500 with a Bang and Olufsen patchcord interconnect connecting PH Phono cable (model # B&O 6270213.)
Can I connect the new CD player which accepts  two RCA male audio cables to the Beomaster 5500 with a Bang & Olufsen 7-Pin Din Male to 2-RCA Male Audio Cable from Cables Online (Part Number: BO-2706)?
Thanks very much for your assistance.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Princetonnj,
Welcome to the forum!  Yes, you can easily connect a CD player that has RCA/Phono/Cinch sockets fitted to your Beomaster 5500 using the B&O cable that you suggested, or I stock a high quality version of this cable that you can see for comparison at the link below:-
http://www.soundsheavenly.co.uk/bando-rca.htm
If you need any further help, please feel free to ask.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
princetonnj
Posts 2
Steve:
Thanks for your quick and helpful response. I have the following questions:
1.    Your website says: “Our five pin DIN cables will fit and work perfectly in the seven pin DIN Aux sockets on newer B&O systems. The extra two pins are only used for remote control data to other B&O products, so they are spare in this application.”
Does this mean that the B&O Master Control Panel and Remote Controller will not work with a non-B&O CD player?
2.    What is the shipping time from the UK to the United States?
Thanks again. I very much appreciate your advice and assistance.
princetonnj
Posts 2,165
Hi Princetonnj,
The B&O Master Panel and Remote Control will select the CD input on the Beomaster, but they will not be able to control the non-B&O CD player.  For this, you will need the remote control from the CD player manufacturer.
I ship items by Airmail free of charge to anywhere in the World, this typically takes 7-14 days to countries outside Europe, with 28 days as a very rare "worst case" when items are held up in customs checks.
If you need any more help, please let me know!
Steve.
Page 1 of 1 (4 items) | RSS
