In January I bought a pair of white BL12-3s which I´m very happy with. For ease of use I also found a used Playmaker MK2 and bought that too. It turned out to be exactly what I needed. Very happy with the option to switch track and also adjust speaker balance from the Beo4.
Some two weeks ago the sound suddenly disappeared from the right channel. The Beolab still turned green when on and red when turned off. Of course I tried adjusting balance, factory resetting the playmaker and switching the “speaker role” to left for the right one and right for the left one. When also this indicated that the issue followed the playmaker I connected it to a pair of Beolab4000 with other cables and also via line in on the playmaker to rule out airplay transmission as the issue.
After this I concluded that the playmaker was dead (on the right channell). I was then super happy to find a playmaker listed and sold locally for 50€, so I picked it up the next day. It all worked well even with long distance to the router and the 2nd playmaker being a MK1.
However now after little use during a bit more than a week I have the same issue with the new one. Only difference is that the sound level is now also very low on the left channel, and again dead on the right channel. Same test procedure gave the same result, the playmaker is damaged.
Now to my question.
-has anyone else had the same experience with the playmaker?
-has anyone had the experience with any sound master that a Beolab speaker “kills it”?
Thanks in advance
//Goran
any suggestions welcome, as currently I don´t dare to try yet another player via Powerlink
BR //Goran
Ah, you know... A little B&O here, a little there
Nope, connected to the playmaker with one of those
https://soundsheavenly.com/bang-olufsen/27-313-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html#/20-length-02m
Also tested with cat6 cable directly to speaker after the issue occurred
Hi BeoMegaMan, thanks for taking your time.
Not quite sure I follow. If I switch speaker role to right channel it goes quiet.
Do you suggest switching it to the still working side (i.e. left) of the playmaker, and letting it play to see if also that channel of the playmaker is than damaged. And that would in turn indicate that it is the speaker that is the root cause?
Isn't the LED on the speaker supposed to turn orange in case of an error, or are there errors in the speaker that aren't caught by the self diagnosis?
That was clear BeoMegaMan, as I mentioned that was the way I started troubleshooting, switching the toggle.
I have now disconnected the left speaker and set the toggle of the right speaker to "left" and connected it to the original MK2 playmaker. it has played like that for a week now without issues.
My question was if you are at all suggesting that a Beolab speaker can somehow give a current/voltage back on any of the Powerlink pins and by that “kill” the player?
Thanks for taking your time
So now some 6 weeks later the playmaker and one Beolab12 is still paying, without issues. Can it really be that I had that much bad luck to get two Playmakers that got faulty within weeks?
1) Has anyone got any ide if a power amplifier as the one in a Beolab can by a fault give a pulse of some kind that “kills” the pre-amp as the one in a Beosound or Playmaker? Or should I just try to find yet another Playmaker and hope for the best.
2) Has anyone experienced or heard that Playmakers are sensitive to lightning strikes? I vaguely recall that there were funder storms during the period that the playmakers were damaged. But that it would in both cases only affect the right channel is again a bit of a mystery.
Thankful for any advice or insight
