A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
I agree with Christian above.
I have myself a beocenter 6-26 used as Radio (with internal tuner), multiroom audio with an Airport Express on scart, and VOD with an Apple TV on DVI.I wake up with radio, live with multiform audio and go to bed with any episode of a TV show or movie. Simple, elegant, no cables (2 actually, hidden).
Ferdinand:The small 26” tv’s came as Beocenter as well including radio tuner if I am correct. I just last week picked up a BS1 cd/radio myself, but being a portable device from the 00’s it is actually quite a beast in size and weight. But plays like a charm.
matador43:I agree with Christian above. I have myself a beocenter 6-26 used as Radio (with internal tuner), multiroom audio with an Airport Express on scart, and VOD with an Apple TV on DVI. I wake up with radio, live with multiform audio and go to bed with any episode of a TV show or movie. Simple, elegant, no cables (2 actually, hidden).
Oh! you're right sorry. I'm using an Apple TV 1 with kodi (with an Atv Skin which make me sometimes forget the layered tricks). Apologies for the confusion.
As for you other question : when radio, the screen is On showing Station, Preset name and RDS info. Mostly dark image overall.And if you wonder, when in mutiroom audio mode, the screen is in Picture Mute Mode, which turn of the panel and the backlight.
But I believe that the timer inside the BC will make your beotime useless for triggering the system.
matador43:Oh! you're right sorry. I'm using an Apple TV 1 with kodi (with an Atv Skin which make me sometimes forget the layered tricks). Apologies for the confusion. As for you other question : when radio, the screen is On showing Station, Preset name and RDS info. Mostly dark image overall. And if you wonder, when in mutiroom audio mode, the screen is in Picture Mute Mode, which turn of the panel and the backlight. But I believe that the timer inside the BC will make your beotime useless for triggering the system.
8000Kristian: I have been through that show before and that hassle ain’t worth it, if you ask me, even though the Beovision/-Center 6 can be bought for peanuts...
Maybe, but here, no hassle at all. I "choose" ATV1 because I'm attached to local storage. All the other function are perfectly controlled with a Beo6, to avoid remotes over remotes and everything works flawlessly for quite a long time now without the less hiccup, even that chinese bluetooth emitter for a BT headphone. And, you're right all for close to peanuts. But it's true it suits my really own needs.
