TAGS
This post has 8 Replies | 3 Followers
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Ƨcɑɽɑɱɑnɡɑ Posted: Sun, Feb 5 2012 5:17 PM
Not that I use them... but where can they be found now?
I just tested some.
  • One B&o bottle opener
  • One fancy gun
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
When TAGS are used they are shown on the right in the tag list and the number of posts with the tag are shown in brackets
Regards Keith....
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
They are there now!
  • One fancy gun
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
Now,
edit (as in post) and edit tags only show in "questions" NOT "discussions"
Will write down and reply to the feedback blog
  • One fancy gun
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sun, Feb 5 2012 7:46 PM
Keith Saunders:
So when Jeff clicks on "Suggest as Answer," it turns into "Verified by burantek?"  Cool.  That's two "Me likey's" in five minutes.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Bit confusing that the name isn't near the avatar.
The Member online message is bigger than the poster's name.
Just a matter of get used to I think.
Beobuddy
Posts 3,972
Just solved I see Big Smile
Keith Saunders
Posts 5,495
Beobuddy:
Is that better now ?
Regards Keith....
Beobuddy
Posts 3,972
Yes, it's better! Maybe a slightly bigger font? Or does that give any problems with longer names?
Page 1 of 1 (9 items) | RSS
