How can I run two digital inputs from BS9000 (for CDSs) and Core (for Tidal) to BL 5s? (I understand that i need to add a optical to coax convertor between Core and BL 5s but still there is only one digital input into the BL 5). Is there a slitter that I can use?
Perhaps pickup a digital/optical audio switcher from Amazon.
Good luck Beoaus
Ray1998:and Core (for Tidal) to BL 5s?
You could use a digital output switch which includes the toshlink to coax convertor:
https://www.cs1.net/products/audio_authority/1177A-1-.htm
I am curious what settings you will use for the BL5. If connected to B&O equipment the digital port will only function if the source "CD" is selected (and communicated via powerlink). You will set it up using option 4?
Regards,
Dennis
The Core has a digital-out as well as a digital-in!
This example could help finding your solution.
(Of course you will need two coax to optical converters there).
Thank you all for your replies and help. Much appreciated.
