If you use a Raspberry Pi as a media centre and get a FLIRC dongle you will be able to control it via Beo4 and the PUC on the BV5. I used to do this on my BV5 and used the Apple PUC that was in my TV.
The FLIRC is a IR reciever. You can teach it any of the choices in the BV5 PUC list.
Stoobie
Yes, you actually "teach" the FLIRC by plugging into PC/laptop and pointing the remote you want to learn at it. In the case of the PUC, you aim the emitter at it and teach it the buttons from the Beo4. Then plug it into your Raspberry Pi.
If you have the correct software on the Raspberry Pi you can plug the FLIRC in an learn the codes via that without the PC step.
I'm currently using one on my Amazon FireTV.
