Hello to everybody,
I recently purchased a used beoplay A1 one and it arrived yesterday, it is used and it said it was perfect,
I can see a gap between the top half and the bottom half (pictures for you to look at could somebody tell me if you were me you'd send it back),
Could anyone offer some advice please,
Betty
If the price was fair and the sound is good, I would not: you soon forget those little details only visible when you look for them.
It was £80, sounds lovely, never heard one in the flesh, so wasnt sure what it should sound like lol,
check if you see the Beoplay A1 in your Bang & Olufsen app to make sure it's no counterfeit. If the app can see and connect to it, everything's fine.
Hi
It's difficult to say for certain as the photograph is very close up. I would say that doesn't look like a Beoplay A1.
In your pic there is a pronounced angular slope between the top and side. The Beoplay A1 has a softer curve on the aluminium speaker cover.
Could you post another image of the whole speaker?
Regards
Opman
w5bno123:It’s upside down
Doh!!! of course it is. I'll get back in my box.
