Restoring a Beocenter 8000 (EEPROM)
Marwal91
Posts 5
Marwal91 Posted: Mon, Sep 16 2019 3:39 PM
Hi !
I received a Beocenter 8000 from a friend that worked fine and then stopped working (no red dot when i plug it, no responding command no "clic" sound BUT the CD laser head is initializing... ) So i guess the problem is from EEPROM (someone told me it could be the point) so i'm looking for help to replace the EEPROM but i need to know more about it. I know that EEPROM is a memory that erase when you plug out the mains. But i know that there is a program inside the EEPROM... So is it working with a battery ? If i replace the EEPROM do i have to replace a battery too?
Thanks for your lights about it !
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 16 2019 9:35 PM
Check the power supply.
Check for cracked solder joints at the large filter capacitors and at the relay.
Marwal91
Posts 5
Marwal91 replied on Tue, Sep 17 2019 3:50 PM
Hi thank you for your help ... My technical English is very poor as a French guy ... So could you be more precise about the parts I have to check ? Maybe if you can send me a picture or a technical drawing about the parts to check that really would help me !! :-) thank you very much !!
matador43
Posts 1,373
matador43 replied on Tue, Sep 17 2019 4:02 PM
Dillen:
Vérifiez l'alimentation principale (avec un voltmètre…)
Dillen:
Vérifiez les soudures au niveau des gros condensateurs et du relais, Elles ne doivent pas être craquelées ou "sèche".
Dillen:
Martin.
Marwal91
Posts 5
Marwal91 replied on Tue, Sep 17 2019 4:19 PM
Merci  !!  Thumbs Up
Dillen
Posts 13,191
Dillen replied on Tue, Sep 17 2019 4:51 PM
Det siger jeg også. Laughing
Page 1 of 1 (6 items) | RSS
