HI
Does this model Apple TV fit into the rear compartment without adjustment? I remember reading a solution recently here, but can no longer find it I think it involved removing something from the compartment
can anyone help?
https://archivedforum2.beoworld.org/forums/p/37141/288966.aspx
Brilliant! Thanks a lot
By the way, can the part be removed without tools, just pulls off?
By the way, does removing the part require tools, or does it just pull out?
thorne:By the way, does removing the part require tools, or does it just pull out?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Finally, where do I put the B&O infrared sensor on ATV4?
Think that’s it. Thanks a lot
