Will Beogram 6500 (model 5946, 220v) work in Belgium (where the standard is 230v) ?
This post has 3 Replies | 0 Followers
Hero71
Posts 79
Hero71 Posted: Sat, Sep 21 2019 10:10 AM
Just want to make sure before I buy.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Sep 21 2019 10:15 AM
For some models I would recommend switching it to the 240V setting if the actual mains voltage is much higher than 230V,
but all 220V B&O audio units should work fine on 220-240V as is.
Hero71
Posts 79
Hero71 replied on Sat, Sep 21 2019 10:42 AM
Hi Martin, thanks for your answer, is the 6500 such a model that you would recommend it for?
Dillen
Posts 13,191
Dillen replied on Sat, Sep 21 2019 10:44 AM
No.
It has a fairly simple yet well dimensioned power supply.
It'll be no problem at all.
Page 1 of 1 (4 items) | RSS
