BL17 + Core vs BL17 + Essence mk2 ?
This post has 4 Replies | 0 Followers
CB
> You are Here <
Posts 1,762
CB Posted: Wed, Sep 25 2019 7:03 AM
Hi everybody
The BL17 can be fed via Powerlink (analog) or Toslink (digital).
In this last case, I suppose the internal DAC of the BL17 is used...
The 2 configurations I would like to compare are:
Core (Optical out) - daisychain fiber wiring - BL17 (Toslink in/out)
Essence mk2 (PL 1&2 out) - Powerlink - BL17
So my question is: do you know if there is an audible difference between the 2 setups?
i.e. is the BL17 DAC better than the Essence mk2 DAC?
Thanks Smile
CB
> You are Here <
Posts 1,762
CB replied on Thu, Sep 26 2019 7:28 PM
Nobody ?
Unsure
Razlaw
Posts 4,345
Razlaw replied on Thu, Sep 26 2019 9:04 PM
I can not specifically answer your questions, but will give you my experience with both. I have an Essence MKII connected by Power Link to a pair of Beolab 4000s. Works and sounds great. I also have a Core connected by optical to a pair of Beolab 50s, previously to Beolab 20s. Again, works and sounds great. I don’t know anything about the technical differences and can’t really compare the sound quality given the totally different speakers.
CB
> You are Here <
Posts 1,762
CB replied on Fri, Sep 27 2019 6:52 AM
Thanks for your feedback anyway Smile
Did you ever connect your 20s by Powerlink to the Core?
Razlaw
Posts 4,345
Razlaw replied on Sat, Sep 28 2019 3:11 AM
No, I did not.
Page 1 of 1 (5 items) | RSS
