so after fixing all issues with Beocord 7000 not playing tapes all was ok for few months.
Suddenly automatic sliding stopped working and I have to manually slide in & out the deck (hearing motor running but not sliding)
Is it something I can easily fix by myself or some big skills are needed?
Broken belt? If so it's not that difficult.
Most likely as motor is running - what belt should I then buy and would there be any tutorial how to change it?
