MLGW + BS9000
This post has 6 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Sun, Sep 29 2019 7:37 PM
I'm beginning with MLGW.
After a full reset, tick on "enable MLGWprotocol over RS232".
With a terminal program when MLGW is powered on we see over RS232 the boot process.
After a while led is green. When sending with BEO4, for example CD, nothing appears on the RS232 !
Should I enable something else ?
(BS9000 MKI SW 2.21, MLGW 2.24 )
Thanks !
beojeff
USA
Posts 2,012
beojeff replied on Tue, Oct 1 2019 1:40 PM
Are you using the web browser interface for programming the MLGW? It has it's own feature for monitoring the B&O data traffic.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Oct 1 2019 1:44 PM
You have to recognize the BS9000 as a "node" on the MLGW via the web interface.There are useful help files here:
http://mlgw.bang-olufsen.dk/source/documents/
Silou
Switzerland
Posts 465
Silou replied on Tue, Oct 1 2019 2:39 PM
Yes I'm using web browser.
Maybe I missed the assignment. I'll try again.
But I can't select BS9000 with "assign single product". Are listed only BV10,6 et BL3500...
Silou
Switzerland
Posts 465
Silou replied on Wed, Oct 2 2019 7:36 AM
it works! But not very useful . You get only sources (CD Tuner) and nothing else. I hope to get more  trafic on ML.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Oct 2 2019 11:26 AM
Silou:
It sounds like perhaps the MLGW has not been reset since the previous owner and still has the previous owner's configuration. You must put the MLGW into a mode to detect your BS9000, then you use a command on the BS9000 for it to be detected by the MLGW. The help files walk you through the process.
Silou
Switzerland
Posts 465
Silou replied on Wed, Oct 2 2019 7:00 PM
Did a all reset an repeated the assignment process
Thanks beojeff
Page 1 of 1 (7 items) | RSS
