Is there a current PUC list available?
the last updated is from March 2013.
https://archivedforum2.beoworld.org/wikis/puc/puc-library-listing.aspx
I have the problem to find a current sat setup box for my Beovision 7/32 MKIII (9331), which can be controlled by the BEO4.
Currently I only have 6 set top boxes in my puc list, all from Technisat and all out of date!
What I need might be puc for
Apple TV 4
fire tv
humax sky receiver
sky q receiver
Blueray player e.g. sony
Best regards
wilfried
Need to talk to your local dealer who can update the list
Leider hat mein letzter Händler vor Ort im Jahr 2019 geschlossen ...
für immer!
those Technisat HD S2 receivers are great SAT settop boxes. The corresponding HD K2 uses the same IR codes as the HD S2 if you need a cable receiver
Try to get a Technisat receiver via eBay. even if the internal hard disk is defect it's no problem because nearly every 3,5" Hard disk with a SATA interface works flawless if used as a spare part!
Just replace the drive and go into the service menu of the technisat and format the drive and everything is fine
You get two independant tuners to record from and view one recording at the same time.
Technisat isio settop boxes use also the same IR codes as the older HD x2 devices.
Ralph-Marcus
RaMaBo: Hi, ....... The corresponding HD K2 uses the same IR codes as the HD S2 if you need a cable receiver Try to get a Technisat receiver via eBay. even if the internal hard disk is defect it's no problem because nearly every 3,5" Hard disk with a SATA interface works flawless if used as a spare part! .... Technisat isio settop boxes use also the same IR codes as the older HD x2 devices.
Hi, the explanation about the Technisat receiver made me very curious.
Is there a list of which functions of the original remote control are transmitted to the BEO4 by the PUC, and which BEO4 keys are occupied by them?
