BV6-26 issues
This post has 6 Replies | 2 Followers
madskp
Denmark
Posts 321
madskp Posted: Mon, Oct 7 2019 7:03 PM
I just aqquired a BV6-26 that someone had thrown out. Aside from some small cosmetic details it is missing the speaker grill, the backcover for the connection panel and has no stan or feet. It is working fine though
Because of the missing speaker grill the speakers looks like this:
Is this something I should try to fix? And if do how? I dont hear anything wrong with the sound when using it.
Regarding stand options can anyone tell me about the feets that was availeble for this tv. Is it simply a little cylinder that is screwed up the button of the TV?
A search on Ebay doesnt bring up feets or speaker grill but maybe im using the wrong search terms. Any suggestions?
Thanks in advance
Stoobietoo
Exeter, Devon, UK
Posts 692
This is what the table stand looks like. Try searching "table stand".
Stoobie
PaulGiles
Posts 218
We have two motorised stands for these in our stores. One faulty
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
Scroll down this old thread to see how I repaired identical speaker damage on a BV6-22.
(Epoxy, matchsticks, pull gently, twist off. )
https://archivedforum2.beoworld.org/forums/t/9635.aspx
Graham
madskp
Denmark
Posts 321
madskp replied on Sat, Oct 12 2019 8:37 AM
Thanks for all the inputs.
Another little question is regarding the remote control.
I have a BEO4 without the PC command in the list function ( and it cannot be added).
Is there another way to activate the DVI port?
PaulGiles
Posts 218
PaulGiles replied on Sun, Oct 13 2019 9:02 PM
Why can’t you add PC?
madskp
Denmark
Posts 321
madskp replied on Mon, Oct 14 2019 5:36 AM
It’s not an availeble item when I choose add to the list function. I guees its because its an old version of the BEO4 no DVD button, but an AV button instead
Page 1 of 1 (7 items) | RSS
