Beovision Eclipse & Dolby Vision Issues
mikewalsh
Posts 13
mikewalsh Posted: Fri, Oct 11 2019 6:50 PM
Hi everyone - need some expert help!
I've had my Beovision Eclipse 65 for a number of years now, connected to an Apple TV 4K, and watching Dolby Vision content without any problems. Lately, when watching Dolby Vision content, my picture has been going haywire. It is OK for about 10 minutes or so, and then starts blacking out, before going to static. I've tried changing to a newer cable, but no difference.
I thought it may have been the dreaded HDMI issue on earlier Eclipses, but my dealer says my Sound Centre serial numbers are above the affected units. He then sent me a technical diagram (attached) which suggests that the B&O Eclipse is not even designed to support Dolby Vision directly into the Sound Centre (other than HDR10), and requires direct connection into the TV (bypassing the surround sound audio processing, and whole point of having B&O in the first place!)
Weirdly, my Beovision Eclipse 55 which is a little newer than my 65 is not having any of these issues, plugged into a similar Apple TV 4k.
Has anyone had similar issues - or know what is going on?
Thanks!
UPDATE:
Thanks for the suggestions - finally solved the issue. Previously I had 'Match Content' setting turned off, because it was generating strange sync effects on screen when you move backwards through menus. I guess that has been addressed in subsequent software updates, and as per the attached B&O technical guide, when I reactivated it, it stopped the issue described above.
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Oct 11 2019 7:23 PM
Maybe obvious question but are you sure it’s not the apple tv? Although the one on the other tv maybe similar, it’s not the same one.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Fri, Oct 11 2019 7:42 PM
Maybe you can try either another HDMI on the sound center or use the native Netflix app through the remote (assuming you use the ATV for Netflix). You can establish if it is your HDMI, the ATV or the tv itself which is faulty
mikewalsh
Posts 13
mikewalsh replied on Wed, Oct 16 2019 7:52 PM
Bieele
Posts 395
Bieele replied on Sun, Oct 20 2019 8:18 PM
Hi Mike,
i have exactly the same issue, thx for sharing your issue and solution.
A few questions;
- I Assume you use the exact settings as desribed in the addendum? Does this mean that you do not activate dolby vision from the atv video setting menu?
- dan you share the complete technical training document? Looks very interesting and I cannot find this in the manual section in beoworld.
thx again and regards,
Dennis
Bieele
Posts 395
Hi Mike,
A few questions;
Dennis
Page 1 of 1 (6 items) | RSS
