Product Config Guide
This post has 9 Replies | 2 Followers
david707
Posts 146
david707 Posted: Tue, Oct 15 2019 5:25 PM
Is it still possible to download the PCG? There is no link from the "products" section of the main site.
Stoobietoo
Exeter, Devon, UK
Posts 692
Go to the users and service guides downloads. Then accessories.  It is then in the dropdown towards the bottom.
Stoobie
david707
Posts 146
david707 replied on Tue, Oct 15 2019 8:37 PM
Excellent. Many thanks - now installed.
David
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 16 2019 9:28 AM
So is there a way of getting this to run on a Windows 10 PC?  I get error messages when I try to run.
I used to have an old XP laptop to run it on, but no more ..
Appreciate anyone's help!
david707
Posts 146
david707 replied on Wed, Oct 16 2019 10:58 AM
Yes you will need an XP PC. I also tried it in Windows 10.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 16 2019 11:30 AM
Thanks David - I thought that may be the case!
RaMaBo
near Munich
Posts 626
RaMaBo replied on Wed, Oct 16 2019 12:51 PM
Hi Guy,
Use the Microsoft Hyper-V feature to install a Windows XP and then in this virtual machine you can install the product configuration guide.
I once did this on a windows 7 pc with the MS integration feature. This was the MS Virtual PC with a MS image of Windows XP.
Ralph-Marcus
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 16 2019 12:57 PM
Thanks Ralph-Marcus - I may well give that a try.
But in the meantime, I just found an old laptop that my mother-in-law had dropped off for me to 'fix'.  I booted it up to discover the wonderful VISTA operating system Unsure, downloaded the PCG and it works perfectly! Smile
Aussie Michael
Melbourne, AU
Posts 3,730
Out of interest what is the Product Config Guide ?
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Oct 17 2019 10:46 AM
It's a simple B&O tool where you can configure a virtual multi room system by choosing what B&O components you have in each room (audio and video), and (for example) whether you are using MCL (like me!) or ML, plus what speakers are being used.  It then gives a quite detailed summary of how to connect the components (what leads are required), and what option settings they should all be in.
It's getting a bit dated now, but I find it very useful to double check my settings, cabling requirements etc.  It can sometimes be useful for answering other people's setup questions on here.
I don't think any modern (NL-era) equipment is included (and I'm not firing up VISTA to check! Big Smile)
Page 1 of 1 (10 items) | RSS
