My wall hinged BV11 has always moved promptly to its viewing position whilst showing the on-off fading Bang Olufsen logo. Then the electronic curtain has opened.
Now, from the beginning of this week, the hinge has only opened after a long delay, and often the electronic curtain opens whilst the screen is still moving to the viewing position.
Has anyone else had a similar experience? Is this the usual problem of a software upgrade making things worse?
Graham
I have a BV11 on motorized wallbracket, and experience no delay when altering the position.
You are aware of that you can have the BV11 in a "quick start" mode, so it does not have to boot up (showing the logo) each time?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: I have a BV11 on motorized wallbracket, and experience no delay when altering the position. You are aware of that you can have the BV11 in a "quick start" mode, so it does not have to boot up (showing the logo) each time?
I haven't changed anything.... I don't use quick start. There is no delay when changing positions when the TV is already on.. it's just that the start-up sequence seems to have changed.
vikinger: Hiort: I have a BV11 on motorized wallbracket, and experience no delay when altering the position. You are aware of that you can have the BV11 in a "quick start" mode, so it does not have to boot up (showing the logo) each time? I haven't changed anything.... I don't use quick start. There is no delay when changing positions when the TV is already on.. it's just that the start-up sequence seems to have changed. Graham
I see,
As I mentioned, I have seen no change in behavior lately. But I run it in quick start mode, so not exactly the same config as you.
Suddenly, the stand / electronic curtain sequence has reverted to normal. Just an aberration?
The other long term issue I've had since the TV was new is that every now and then the motorised hinge creeps out at half speed. Probably 1 out of 20 operations. I've always assumed this to be another software glitch ( that B&O haven't bothered to address after 6 years).
vikinger:Suddenly, the stand / electronic curtain sequence has reverted to normal. Just an aberration? The other long term issue I've had since the TV was new is that every now and then the motorised hinge creeps out at half speed. Probably 1 out of 20 operations. I've always assumed this to be another software glitch ( that B&O haven't bothered to address after 6 years). Graham
