Hi guys,
need help here.
i just tried setting my BS5 encore up with a NAS (QNAP 219 II, twonky 6.0.39) , wired thru a dlink router.
All devices see the NAS except the BS5. On the Twonky I see BS5 has made contact with it as a B&O media receiver.
Replaced the NAS with a pc running twonky 7 server, same result.
what am I missing here????
Thanks in advance.
did you instruct the BS5e to which media server to connect to? Do as instructed above
Thanks Michael.
It's a new BS5 and it never had any NAS connections.
Do I just do the "double right and go" at any place?
I had my arm pointing at "mode" and I get the selection of "radio" "a.aux" and "settings"
Did that sequence and nothing happened.....am I supposed to get into another "setup menu"?
Thanks again
When you do the "right left right left go" thing, the item selected has to be "parameters" (or settings, my Encore is not in English, so I can't name the exact word). Then you will have a settings menu with some new elements, like the NAS selection!
diisign.com
Thanks mbee, that did the trick.
