Dear Sirs., I lived in Brazil and I am owner of a Beocenter 7000 and 7002 and I am interested to buy from Ebay UK, two printed circuit boards that the announcer dismounted from Beocenter 5000.
In acccordance with the diagrams I have available for 7000/7002, the part numbers are: 8002356 (PC 5) and 8004210 (PC 11).
The printed circuit PC5, from the add, only state that can be suitable for 7000/7702 and I have to check.
The printed circuit PC11, from the add, also state that can be suitable for 7000.7002 and on the picture shows a label with the part number 2372011.
Are the PC5 and PC11 from Beocenter 5000 suitable for the Beocenter 7000/7002?
Module 5 8002356 is correct for Beocenter 5000, 7000 and 7002. You can see it here:https://beoparts.com/2015/06/27/volume-control-circuit-board-pcb-8002356/
Module 11, 8004210 is correct for Beocenter 5000 and 7000 (not 7002).
Numbers on the board itself can be partnumbers of the circuitboards without components - don't use those as reference.
Martin, thank you very much for your reply and the valuable remark regarding the part number printed on each PCB, which can refer to the circuit boards without components.
By the way, I also kindly ask you to confirm me that the following four modules from Beocenter 5000, that I am getting from the supplier, it is correct for 7000/7002 too :
Module 1&2 (8050071 & 8002354) and
Module 3&4 Power Supply and Output Amplifier (8002358 & 8002413).
Thanks in advance and best regards, Walter.
