Good evening
I am so sorry if this has been discussed and solved before, but I cannot seem to get the other guides to work.
I have a BeoSound 3000 mk1, a BeoLab 3500 (old one with MCL) and a Beo4 remote.
They are playing in the same room, but I cannot control the volume with the remote. The Beosound 3000 is set to A.OPT 1. Is it possible to use the same Beo4 to control the 3500`s?
Best regards Kristian L
MokiPhone:Good evening I am so sorry if this has been discussed and solved before, but I cannot seem to get the other guides to work. I have a BeoSound 3000 mk1, a BeoLab 3500 (old one with MCL) and a Beo4 remote. They are playing in the same room, but I cannot control the volume with the remote. The Beosound 3000 is set to A.OPT 1. Is it possible to use the same Beo4 to control the 3500`s? Best regards Kristian L
