HI if you go into android setting it tells you all also updates remote 1 and advises you might need to change your batteries as data base updates but shows it on your remote screen
m welborn
Mine did that too - nothing seems to have changed...
best regards Elmar
malcolm welborn:HI if you go into android setting it tells you all also updates remote 1 and advises you might need to change your batteries as data base updates but shows it on your remote screen m welborn
Horizon was also updates and Beoremote One.
and now BR1 gets updated every time I switch off the TV....
