Hi everyone,
things have been pretty quiet until.....yes, until another little issue on the BM8000 !
in TP2 mode I lost the left channel - it comes on briefly after selecting TP2 and crackles out.
first I suspected IC1 being at fault, replaced it ...no change !
second I checked the connector box with the assigned 5Pin DIN input....all fine !
both trimmers R122/222 are new, only R122 shows audible change when turned, no reaction from R222 though as well as both assigned caps C112/212.
phono and TP1 work fine....does this exclude IC202 as a possible source of the issue ?
at the moment I can not see any other source guilty of causing that issue.....can one of you help ?
regards
ALF
To avoid misunderstanding C112/212 are new.
connection from PCB3 P14 to PCB9 P82 is fine as well !
Transferred a spare (not really spare) preamp board and the missing left channel in TP2 input mode is back 😁😁
my suspicion is going to the two switching ICs on board 3. Naturally those ICs are long gone.....the famous needle in the hay stack.
i can not see any other culprit on that board causing that kind of issue.
I checked the R222 trimmer and the designated cap...both fine and as said, IC1 has been replaced....what is left is that damn switching IC.
that is my diagnose.....but sadly no help/support ?!?
Have you seen this:
https://archivedforum2.beoworld.org/forums/t/33383.aspx
Thanks for the reminder Martin, much appreciated.
I made contact with John (sonavor) and yes indeed, the AD10/278 chips are the source of the issue my BM has.
the existing pair will be replaced by the new device !
alf
