Beoplay E8 2.0 - Only sound from right player
This post has 3 Replies | 2 Followers
Jan Præst
Denmark
Posts 34
Jan Præst Posted: Wed, Oct 30 2019 11:42 AM
Can't get sound from both earplugs, only the the right player!
Does any one have a suggestion to solve this?
Regards
Jan Præst
BeoLap 17, BeoLap 3500, Beosound 35, BeoSystem 4, BeoPlay A2 Active, Beovision Eclipse 55, Beoplay E8 2.0, Beolap 19
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Oct 31 2019 6:59 AM
If you have not done that, do  reset of the earbuds.
To reset, touch and hold the left and right earphone simultaneously until the product indicator is flashing red (approximately 10 seconds).
Beoplay E8 will turn off once the reset is completed.
Jan Præst
Denmark
Posts 34
Thx Hiort. It did the trick ;-)
Regards
Jan Præst
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Oct 31 2019 8:24 AM
Jan Præst:
Glad it worked for you. Sometimes putting both buds back in the case, and take them out again also helps.
I rarely have the problem that only rigjht bud (who is the master) is playing.
Use mine on daily commute to / from work Smile
Page 1 of 1 (4 items) | RSS
