I recently brought a used Beoplay S8 sub (witch I believe is identical with Beolab 14) but it seams that I can get any power on it. The LED underneth shows no light - nor is there any other sign of life.
I've tried to connect it to my Beovision 10 to the sub outlet as well as the front.
Any suggestions or known issues?
Best Regards
Anders, Denmark
Have you enabled the sub in sound settings on the TV?
Dumb question, maybe?
Have you connected the sub to the mains?
Do you notice any activity from the small led at the buttom?
Also see here:
https://archivedforum2.beoworld.org/forums/t/8212.aspx
I have both the sub and the TV connected to mains. and subwoofer eneabled i the speakermenu on the BV10.
Does anyone have the servicemanual for Beolab 14/Beoplay S8?
