Beogram RX2
dansker1
Posts 2
dansker1 Posted: Thu, Nov 14 2019 11:19 PM
I just received this unit.  Following the instructions pressing "PLAY" the tonearm keep hovering above the groove of the record, but does not lowers the stylus into the lead grove of the record. When touching "PLAY" again, the tonearm returns to its resting position.
I was wondering if the tonearm has a special fastener for shipment, as it hard to lift it up or press it down. If this is not the case, can anyone recommend a service person/company that are familiar with B&O?
I would be grateful for suggestion as I am not very technically minded.
Thanks Kurt
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Nov 15 2019 6:55 AM
Cartridge fitted?
Tracking force set correctly?
dansker1
Posts 2
dansker1 replied on Fri, Nov 15 2019 11:11 PM
Hello Martin, Yes the cartridge is on the tonearm, and the tracking is set to 1.5 which I read is is required for a M5 cartridge.
Can the tonearm be locked for shipping?
Dillen
Posts 13,191
Dillen replied on Sat, Nov 16 2019 8:01 AM
No.
Transport screws losened?
Can you feel the tiny weight of the tonearm if you lift it gently - or is it just floating?
Page 1 of 1 (4 items) | RSS
