Hallo Kopfnuss,
die ist da 'General Forum, wo die meisten in Englisch kommunizieren, deshalb weiter in Englisch:
To connect the bc9500 and the BV10 you need the Beolink Converter 1611 or 1614. Additional you need a masterlink cable betwenn the BV and the Converter, an Audio-AUX cable ( 7 pin DIN cable).
Both could be obtained from Steve at Soundsheavenly ( see link at bottom of page). He is very helpful!
To setup the system you need to put the BC and the BV into standby1 then get your BL 1000 ( it's the easiest way). and press <SOUND> <2> <STORE> and then <PICTURE> <0> <STORE>. this setting let the BV ignore the IR Commands and the BC react to Audio _and_ Video commands. The video commands will be routed to the BV via the Beolink converter and Masterlink cable.
Now disconnect the BC and the BV from the mains, wait about 30 seconds and then connect the Audio-AUX cable to the BC9500 (A.AUX/TV socket) and the Beolink converter and the masterlink cable to the converter and the BV10.
The next step is to connect the BC9500 to the mains, wait about 30 seconds, then connect the BV10 to the mains, again wait about 30 seonds and finally connect the Beolink converter to the mains and again waiting about 30 seconds.
Now the system should work as desired: Everything is controlled via your IR Remote. Audio sources will be played through your Pentas as before. Also the Video sound will be heard . The Pentas should show TV for TV, V.Tape for your V.Tpe (V.MEM) and so on.
Ralph-Marcus
Try to get a 1611, this can be used more versatile than the 1614, but the 1614 will do it's job also in your case.
