Beolab 2 met Beolab 8000 op sonos connect aansluiten
Piet Hansen
Posts 12
Piet Hansen Posted: Sun, Nov 24 2019 10:05 PM
Hallo
Kan iemand bij helpen hoe ik mijn Beolab 2 en 8000's aan moet sluiten op een sonos connect? Ik moet er een trigger tussen zetten, maar ik wil graag dat alles automatisch aan en uit gaat. Dus wanneer ik muziek afspeel springt hij aan, zet ik de muziek uit springt hij uit. Iemand tips?
Alvast bedankt voor de hulp.
Mvg,
Piet H
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hallo Piet,
Sorry for replying in English!
The cables that I usually make for the Sonos to Beolab 2 need manual control (https://soundsheavenly.com/line-in-connection/101-459-singletwin-rca-to-beolab-2-7-10-2500-powered-trigger-kit.html#/2-length-1m).  However, if you use the Tibo 2 wireless player instead of Sonos Connect then this has a Powerlink socket fitted to give full automatic control of the speakers:-
https://soundsheavenly.com/bang-olufsen/179-wireless-music-streamer-for-beolab-speakers-and-beosound-music-systems.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Piet Hansen
Posts 12
Hello,
Thank you for your answer.
Is it possible through a Bang and Olufsen connection hub?
Link: https://www.sportique.com/products/bang-olufsen-beoplay-s8-connection-hub-black-1625026
Thanks!
Piet Hansen
Posts 12
Hello,
Thanks!
Posts 2,165
Yes, you can use a B&O Connection Hub.  This cable goes from the Sonos Connect to the 3.5mm input of the Hub:-
https://soundsheavenly.com/hifi-av/112-498-minijack-to-twin-phono-rca-line-ipod-to-hifi.html#/2-length-1m
This cable goes from the Hub to the subwoofer:-
https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m
The other Beolab speakers then connect to the sobwoofer with normal Powerlink cables:-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-272-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/9-length-18m
Steve.
Page 1 of 1 (5 items) | RSS
