Hi guys, I received my besound moment few months ago but I was in the middle of relocating for good. So yesterday, I unboxed everything ( from dealer ) and to my surprise the screen has clouding and light bleeding on the edge.
Attached some pictures for your reference. Is there anything I can do about it? Is this even normal or does it qualify for repair ?
I bought a BeoSound Moment.
It was a moment of madness.
Would you please elaborate?
I have two Moments; one does this, while the other does not. I moved the one with the bleeding to the office where I never operate in the dark. With room lights turned on it is not at all noticeable, so I haven't concerned myself further.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
Hello,
Dealer was able to replace my beosound moment. Now I have a bigger issue. I can't get it to work. I tried resetting and restarting but I'm getting the following issue although I have a working internet connection both through WIFI and LAN.
