I an offer to buy a Beovision 10-40 cheap, 400 euro. From 2009. Is it a bad idea? I mean I see so many where the panel is defect and cannot be repaired. What do you think? Is all BV10-40 bad and suddently goes defect?
For 400 euro I would certainly give it a go.
Had it before my BV11-46 and its a nice TV, and the last with Masterlink if you fancy that.
Make sure the seller is a trustworthy person.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
No regrets following buying my 10 40 a year ago for the bedroom. With an Apple TV connected it’s perfect, great set for looks and performance in my book. Yours sounds a bargain too!
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Beovision 10 great for a number of reasons
FullHD tuner
1080 resolution
HDMI
Masterlink
….but bad sound
I purchased a MK1 BV10-40 almost 2 years ago and it has treated me really well. I went for one with a motor stand and it is a joy to use on a daily basis.
Only downside is the sound. If you want powerful sound, you will definitely need an extra set of speakers to supplement. I run mine with BeoLab 8000s and it makes for an excellent setup.
Beo4 'til I die!
I used to own a BV10 and miss that bright orange fret! If I could get another for the bedroom, I would for 400 €
For 400 euros this would be an excellent buy IMHO. At 40 inches 4K is not that important. There is no modern set you can get at this price that looks so great - especially with the motorized floor stand. I would buy it in a heartbeat if I needed a 40 Inch screen.
B&O in my life 😊:
To buy 10 years old tv? I would never take one for free
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Hi Guys,
The sound quality rise many times here. I wonder how does this quality compare with a Beocenter/Beovision 6/26.
The fact is I did recently see two BV6/32 for 350€ with remote and stand and I was tempted to replace my BC6.But that would be only for aesthetics reasons since the BC6 is currently perfectly configured to my tastes (Atv, Airplay, Radio) and the sound, as much as the picture are more than enough not to say perfect.
So how do the the BV10(32) compare with it?
So did you buy it? someone else will grab it at that price if you wait longer
