Dont say anything....
This post has 195 Replies | 1 Follower
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
and now the emitter of transistor 151......looks suspect
Craig
Posts 2,040
Silver Member
Had a good go at this today and pulled transistor 151.....however it tested out fine, but I replaced him anyway just to be sure.
Craig
Posts 2,040
Silver Member
Next I went after capacitor 152....he was also good, but I replaced him too
Craig
Posts 2,040
Silver Member
following on I went after the capacitor on the base...….this one
Craig
Posts 2,040
Silver Member
However when I threatened it with the soldering iron I noticed both legs where actually soldered together on the board, shorting them out in effect....this pic was taken after I cleaned off the excess solder and separated the two points, I am going to blame this on soldering in components with the board in the vertical plane encouraging  the solder to flow down Unsure
Craig
Posts 2,040
Silver Member
Encoraged by this find I hooked up the sig gen and scope once more......
Craig
Posts 2,040
Silver Member
And was rewarded with this reading at the emitter of transistor 151...…..
Craig
Posts 2,040
Silver Member
confident I had located the issue I went on to hook up the good doctors Thornes once again and ow both channels sound excellent once again.....happily this concludes the component replacement exercise......
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Feb 1 2020 4:08 PM
I recognize that Alan Parson record! Good work Craig.
Are you going to replace the rusty DIN sockets?
Jacques
Craig
Posts 2,040
Silver Member
Jacques
Your right of course....I like a bit of Alan Parson, as for the DIN sockets I hadn't planned on drilling out the rivets to remove them, I will have a go with the Dremel to remove as much oxidation as I can then take stock. Meanwhile I have spent a bit of time looking at the condition of the cursers, I have new lens provided by Martin but still need to do something with the lens holder.....they are quite yellow with age.
Craig
Posts 2,040
Silver Member
I have tried soaking one in sterilizing fluid overnight, the lens holder is much improved....but when compared with one of Martins replacements the lens is still quite opaque...….
Craig
Posts 2,040
Silver Member
Spent a little time on the damaged corners of the pre-amp/tone control board.....super glued the broken bits in place then gave them a liberal covering of epoxy resin.....
Craig
Posts 2,040
Silver Member
I'm optimistic that they will hold for some time....
Craig
Posts 2,040
Silver Member
And just for a change of pace did a little mindless sanding on the top, removed the old varnish....there are one or two dings that are too deep to sand out and will bave to be lived with. Bees wax and a good polish will finish it off.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Feb 3 2020 7:01 PM
I seem to recall that Frede also does those wooden parts and that they look like fresh from the factory. Whistle
Jacques
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Mon, Feb 3 2020 10:03 PM
Craig,
What's the temperature set point of your soldering pen?
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Feb 4 2020 8:07 AM
I didnt know Frede provided cabinet parts too......as for my soldering iron, its not an expensive one so i'm not confident about the accuracy of the temperature setting but Ihave it around 450 degC.......
Craig
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Feb 4 2020 1:34 PM
Which is definitely too much. I always use 370 Celsius.
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
I use 350°C for soldering and up to 380°C for desoldering only on very big solder points (not on PCBs) I go higher
Craig
Posts 2,040
Silver Member
Fair enough....I have wound my temperature setting to 350°C......thanks for those words of wisdom ;¬)
At Jacques suggestion I have had a look at the DIN connectors...I don't think the condition warrants drilling out the rivets just yet......
Craig
Posts 2,040
Silver Member
And from the outside.....
Craig
Posts 2,040
Silver Member
I'm thinking a bit more of a clean up inside, particularly around the RCA connectors should be fine.....had a look at the panel complete with Martins lens.....lens holders came up good and once all assembled they look like new.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Wed, Feb 5 2020 8:33 PM
Nice to see things coming together.
-sonavor
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Feb 6 2020 2:31 PM
Craig:
So beautiful when it’s new—which it is, isn’t it? Stick out tongue
Jacques
Craig
Posts 2,040
Silver Member
Well.....look what turned up in the post today!
Craig
Posts 2,040
Silver Member
And nestled inside was the lens donated by Charles, much appreciated as these are quite a rare animal....I owe you one my friend ;¬)
Craig
Steve_hayes8310
Posts 5
Hi Craig who is Frede and what service does he offer?
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Mar 16 2020 8:08 PM
Hi Steve
Frede Kristensen is a legend in these circles....he is Classic Audio, other members will know a lot more about him than I. He provides services and guidance to members of this forum and has a wealth of knowledge from his years as a B&O design engineer, I don't know the full extent of his services but I'm sure others can advise you.
Craig
Posts 2,040
Silver Member
Next step is to remove the remains of the damaged lens from my panel....
Craig
Posts 2,040
Silver Member
Little help from the Dremel removed the stubborn fragments at the bottom...
Craig
Posts 2,040
Silver Member
And there he is.....in his new home.
Craig
Posts 2,040
Silver Member
Finished article......these are such a delight
beocool
Alankomaat
Posts 6,194
beocool replied on Tue, Mar 17 2020 8:24 AM
Job well done! Congrats Smile
Vähintään yhdeksänkymmentä prosenttia suomalainen!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Mar 17 2020 9:35 AM
Great result!
Now on to the next! Laughing
beocool
Alankomaat
Posts 6,194
beocool replied on Tue, Mar 17 2020 11:37 AM
Steve_hayes8310:
Link to his website: https://www.classic-audio.dk/
Beo_Jean
QC, Canada
Posts 334
Beo_Jean replied on Tue, Mar 17 2020 11:46 PM
I'm glad it made the travel safely!
You owe me nothing other than keeping me entertained with your future projects!
Congrats!
Page 5 of 5 (196 items) < Previous 1 2 3 4 5 | RSS
