I just got my BeoVison Harmony this weekend.
Really everything super ... Super finishes, Super picture quality and super sound
But now it comes ... the B&O Harmony Soundcenter (where the LG Panel is connected) doesn't have its own audio player for a NAS in the house. The only audio player for streaming music is the one from LG and it can't support a FLAG 192/96 or ALAC.
I try to connect the WebOS Audio Player withy NAS (UPNP and DLNA) but nothing work ...
Every A9 can connect to a NAS ... Whats wrong?
I want to use the Harmony as my Audio Center ... and now?
Best Thomas
What about when you configure the Harmony/Sound Center in the Bang & Olufsen app.
It should work like any other ‘modern B&O audio system’....as far as I know.
Thanks for the hint ...
I set-up a Plex Media Server (DLNA enabled on my Mac mini (I use the Mac as my Music Server ) and give the Beo App access to the Server. Now I can control my Music with the Beo App. But the Player on the Harmony is the LG Player with a horrible Interface ;-)
Any Hint about to Hide the LG default Apps (Galerie, Video ...), I could delete all other installed Apps ..
and Greetings from Hamburg
Fansastic:Any other NL speakers or Beosound Moment in your network? If so are you able to play DLNA music from that source and join in the Harmony? Hope this helps
SoundsGood:Any Hint about to Hide the LG default Apps (Galerie, Video ...), I could delete all other installed Apps ..
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
SoundsGood: Thanks for the hint ... I set-up a Plex Media Server (DLNA enabled on my Mac mini (I use the Mac as my Music Server ) and give the Beo App access to the Server. Now I can control my Music with the Beo App. But the Player on the Harmony is the LG Player with a horrible Interface ;-) Any Hint about to Hide the LG default Apps (Galerie, Video ...), I could delete all other installed Apps .. Best Thomas and Greetings from Hamburg
If you stream like Carolpa writes, you use the Harmony in audio mode.
The plan is, that the Harmony - with a coming update - should be able to display some infos/metadata on the screen in audio mode.
However, when this will happen and exactly how is still unknown.
Maybe you are expecting a media player from B&O (like e.g. In the BV11) on the screen of the tv.
There is no such - you have the LG-one (which you find ‘horrible’).
I guess it is a matter of which ‘player’ you choose as end point for the DLNA stream!
Maybe you can install another media player from the LG app store, that suits your needs better (e.g. a Plex app).......if you want to use the screen/see metadata, coverpics etc there.
I am not familiar with what you can install - but that could be googled.
Hope this helps.
SoundsGood:I just got my BeoVison Harmony this weekend. Really everything super ... Super finishes, Super picture quality and super sound But now it comes ... the B&O Harmony Soundcenter (where the LG Panel is connected) doesn't have its own audio player for a NAS in the house. The only audio player for streaming music is the one from LG and it can't support a FLAG 192/96 or ALAC. I try to connect the WebOS Audio Player withy NAS (UPNP and DLNA) but nothing work ... Every A9 can connect to a NAS ... Whats wrong? I want to use the Harmony as my Audio Center ... and now? Best Thomas
Carolpa:hello Tomas . Actually the LG app supports 24/192 stereo FLAC
Carolpa:sorry it is 24/96! The same for PCM/Wav
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia: Carolpa: sorry it is 24/96! The same for PCM/Wav Unless you have 50’s or 90’s that’s fine anyway
sorry it is 24/96!
Not if you have some 192 files, that you want to play ;-)
If you have 192 files, you probably want to play them back as is.....now that you have paid a whole lot of money for them ;-)
attention:
the LG app goes up to 96kHz
the B&o app streaming to the Harmony goes up to 192kHz
