beocord 9000
This post has 6 Replies | 0 Followers
lotus73jps
Posts 141
lotus73jps Posted: Fri, Dec 20 2019 12:12 PM
hi the ppm recording level indicator on both left and right channels are not showing on record and playback  .so cannot record a tape need help as to what to look for ?thanks
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Dec 20 2019 12:18 PM
Correct cable used?
Input selector set correctly?
lotus73jps
Posts 141
lotus73jps replied on Fri, Dec 20 2019 12:40 PM
hi martin cable is 7 pin from steve and input selector is   amp and level is line
Dillen
Posts 13,191
Dillen replied on Fri, Dec 20 2019 12:53 PM
RECORD OPEN lit?
lotus73jps
Posts 141
hi martin yes the record is lit and the no store is flashing
Dillen
Posts 13,191
Dillen replied on Sat, Dec 21 2019 7:53 AM
If you are sure, that you actually have an output from whatever you record from, check the signal path inside the Beocord with a scope.
It could easily be a capacitor causing a missing voltage somewhere.
lotus73jps
Posts 141
lotus73jps replied on Sat, Dec 21 2019 10:50 AM
hi martin ive hooked the 9000 to 3 of my units beomaster 8000 and 2 beocenters 9500 still the same results .as I have no clue were to start looking for signal path or capacitor it will have to go back on the shelf  . until I can find somebody like you who nows what there doing .once again martin thanks for your help
Page 1 of 1 (7 items) | RSS
