Can I connect these two together and listen to my iTunes music through the Beosound 3?
The BeoSound 3 doesn't have any input other than the SD card.
A way to do it would be to get af FM transmitter and tune the radio on the BS3 into the right frequency.
Might not get the best sound, and I am not sure about the distance you can have between the BS3 and the transmitter without to much interference.
It does have an earphone socket. Would that do to connect airport express?
BV 11-46 / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
