My X-mas present BeoLab 5000 and BeoMaster 5000.
This post has 60 Replies | 1 Follower
Martynka
Poland
Posts 245
Martynka replied on Sun, Mar 22 2020 11:11 AM
@chartz, inside Beolab... yes I know about PCB tracks and transistors but did you see internal wires between power transistors and PCB ( audio line ) ?? It is about 1,5 mm2 , between PCB and capacitors the same 1,5 mm2 and the same goes to the selection switches, then only 0,5 mm2 goes to the DIN connectors. One more time - only 0,5 mm2 goes to the DIN connectors to supply 60W power (less than 4ohm). I just only missed the weakest link.
Inside Beovox, yes I had the same thin wires but I changed it like always to 1,5mm2
My new cables is a 2,5mm2 oxygen free cooper for audio use with thick insulation.
In my opinion if you have about 10 meters between amplifier and speakers and you want use sometimes this cable with more powerfull power amplifier ( like Yamaha M2 ) and with harder to drive speakers this 2,5 mm2 is minimum.
Besides, as you noticed I didn't destroy Beolab, and it looks aesthetic.
BeO is like a good wine - the older the better...
Martynka
Poland
Posts 245
Martynka replied on Sun, Mar 22 2020 2:02 PM
Here you are comparison from Beolab. In this green oval you can see thick blue and red wires. It is the same dimension like all audio line. You can see also red, blue and black spiral thin wires. It is the same dimension like audio line from selector switches to DIN.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 22 2020 3:15 PM
Larger lead dimensions won't hurt, I suppose.
But, to be honest, I think you would experience a much greater improvement if you replaced those old output series capacitors.
They were very high quality components when new, but they live in warm surroundings and are 50+ years old so will have past their best days.
Perhaps the capacitors in general.
Martynka
Poland
Posts 245
Martynka replied on Sun, Mar 22 2020 3:35 PM
@Dillen, you have right like always. In this moment I try to find 3000uF capacitors. In both I have measured 4000uF but you know that it can be worster when Beolab work.
Dillen
Posts 13,191
Dillen replied on Sun, Mar 22 2020 4:59 PM
3300uF would be fine.
Martynka
Poland
Posts 245
Martynka replied on Sun, Mar 22 2020 5:34 PM
Thanks,
and what with 2500 uF / 100V ??
Dillen
Posts 13,191
Dillen replied on Sun, Mar 22 2020 5:54 PM
General handrule:
Don't go lower - and don't go much higher - in working voltage rating than the original.
If the original cap is 70V, see if you can find this or 80V.
A cap with a 100V rating may sound like a better choice, - but it isn't.
A capacitor is in some ways like a rechargeable battery, if it only ever sees a fraction of its nominated voltage it will die fast.
Don't go lower - and don't go much higher - in capacitance than the original.
If the original cap is a 3000uF, see if you can find a 3300uF.
Martynka
Poland
Posts 245
Martynka replied on Sun, Mar 22 2020 6:58 PM
I ordered  Mundorf MLytic MLGO AG 3300uF 63V and still searching 2500uF/100V.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Mar 22 2020 10:57 PM
A 2200 uF will be fine!
Jacques
Dillen
Posts 13,191
Dillen replied on Mon, Mar 23 2020 7:43 AM
Or 2700uF
Martynka
Poland
Posts 245
Martynka replied on Mon, Mar 23 2020 9:21 AM
I have in home my 2200uF/100V TDK/EPCOS with screw terminal (low ESR and high rated ripple current), I try first this.
Dillen
Posts 13,191
Dillen replied on Mon, Mar 23 2020 9:39 AM
I really wouldn't choose a low-ESR component for the filter capacitor.
The rush-in current will give the rectifier and the transformer a harder life.
Low-ESR capacitors can be used in the preamplifier section and, perhaps, if you cannot find something closer to the original, as the output series capacitors.
Martynka
Poland
Posts 245
Martynka replied on Mon, Mar 23 2020 10:10 AM
It's my fault, I mean lower than similar capacitors, about 40 to max 80 mohm vs 60 to max 100 mohm and max 13A to 4,4 vs  5A  to 2,2A compared with Nichicon and other witch I found. I think TDK/EPCOS will be OK.
Martynka
Poland
Posts 245
Martynka replied on Tue, Mar 24 2020 6:48 PM
I still wait for a Mundorf caps but I changed 2500uF power capacitor.
and .... Is it possible that now Beolab play louder and stronger ??
it is like I increase preamplifier level but I didn't touch input regulators.
Martynka
Poland
Posts 245
Martynka replied on Thu, Mar 26 2020 8:09 PM
Today I piked up this little beauties
little 3300uF compared to old one 3000uF:
Because I didn't want overheat caps I prepared rounded connector to capacitor pin, after that I soldered wires to connector and on the end I put conector with wires on capacitor and soldered it.
and finally my new Beolab power capacitors family:
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Mar 27 2020 5:32 PM
Did you measure the old caps?
I’d be surprised if they were bad.
For good measure I have replaced may of those Wicon electrolytics over the years, but they were incredibly durable and returned low ESR and acceptable precision.
Anyway, good job šŸ‘šŸ»
Any difference? Have the new caps reduced the switch-on thump?
Jacques
Martynka
Poland
Posts 245
Martynka replied on Fri, Mar 27 2020 6:31 PM
@chartz.. switch-on thump was little bit reduced when I put EPCOS/TDK 2200, but a very little bit. The same when I changing source.
Yes, all old capacitors are over range:
2500uF -> 3800 uF
3000uF -> 4200 uF
3000uF -> 4100 uF
Difference... yes, Beolab play more powerfull and louder , a little something like you push "Loudness". When I stand next to the loudspeaker and choose vinyl to play next and the music play low, I feel like my trouser legs are rubbing against my legs. WOW.
Everything I did before improved the bass, now I opened up the highs. But In the same time I changed caps in 5702 crossovers and I don't know witch caps opened up this.
And this Beovox 5702.... excellent and amazing and very underrated. After all changes inside I have the best treble what I heard ever and bass stronger than M70.
Dillen
Posts 13,191
Dillen replied on Fri, Mar 27 2020 8:35 PM
Martynka:
2500uF -> 3800 uF
3000uF -> 4200 uF
3000uF -> 4100 uF
That's the result of the damping factor being restored.
The lower output impedance of the amplifier, the more control over the coils in the speakers.
Think of the coils being almost shorted by the amplifier, "grabbing, moving and braking" them. With worn out capacitors in series the "grab" won't be as tight and sound won't be as precise but instead it will feel more "elastic".
Martynka
Poland
Posts 245
Martynka replied on Fri, Mar 27 2020 11:17 PM
One more question @Dillen, after replaced 2500uF/100V I hear more noise from turntable. Touching the Beogram or walking next to the Beogram is transmitted to the speakers with interference. I think that Beogram sounds better, more detailed but with more distorsion.
Martynka
Poland
Posts 245
Martynka replied on Tue, Apr 21 2020 6:40 PM
Problem solved, Beogram cable was broken Smile
Martynka
Poland
Posts 245
Martynka replied on Fri, May 1 2020 12:10 PM
New BeOlover in my family:
My audiophile cat
Page 2 of 2 (61 items) < Previous 1 2 | RSS
