How do I setup Lutron Caseta with BLGW?
kmortenesi
Posts 34
kmortenesi Posted: Fri, Dec 27 2019 10:09 PM
I have just acquired the latest version of a BLGW. When I look under the supported systems I see several Lutron options, but not the Caseta model that I also recently installed. I got the Caseta PRO in order to be able to integrate with 3rd party systems, such as B&O.
Does anyone know how to set this up in the Systems menu? I also tried looking for additional system drivers to install, but no luck...
beojeff
USA
Posts 2,012
beojeff replied on Sat, Dec 28 2019 1:20 PM
The BLGW currently only works with RadioRa2 or Homeworks QS.
I recently spoke with someone at Lutron who told me that Lutron is now seeing the Caseta line as a mistake and that it could possibly be phased out in favor of the RA2 Select system for DIY users. The good news about RA2 Select is that all of the dimmers and remotes are compatible with RadioRa2 if you ever chose to upgrade the main repeater.
BeoMatthew
Posts 46
Caseta is built on the QS protocol. I believe it's the same driver as HomeWorks & RA2. If I recall it does have Caseta by name. Ikatu, the developer of the BLGW platform confirms it's supported. http://www.ikatu.us/beolink-gateway.html
kmortenesi
Posts 34
kmortenesi replied on Sat, Dec 28 2019 10:22 PM
Thanks. I picked this and I’m now able to connect to my Caseta bridge (status is green). Next I need to determine IDs etc for my lights so that I can control them in the macros. No luck yet
Page 1 of 1 (4 items) | RSS
