DVD1: Power light enable/disable
Mark
Malvern
Posts 381
Mark Posted: Tue, Dec 31 2019 8:15 PM
I have two DVD1 players. On one, a red dot lights up when it's powered. On the other, the display remains blank (black) unless a DVD is actually playing. Is the power dot enabled through a configuration option?
Mark
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jan 1 2020 9:17 AM
If they are Mk1s (Type Number 4620) then on the Functions menu there's a 'Low Power Standby' setting (ON or OFF) - try toggling that.
Mark
Malvern
Posts 381
Mark replied on Wed, Jan 1 2020 10:18 PM
Looked like a good idea, and they're both Mk1 players...
The one where the power indicator works was set to "off" whilst the one where it never comes on was set to "on". However changing the flag had no visible effect on either DVD1 front panel Sad
So thank you for the idea, but sadly it didn't solve the problem!
Mark
Mark
Malvern
Posts 381
Mark replied on Sun, Jan 5 2020 8:10 PM
Solved! Guy, thank you again for your help - it allowed me to rule out the "settings" as the cause of the problem. It turned out to be a dirty connector. Once the front panel connector was unplugged and re-plugged, the standby indicator magically started working.
Mark
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jan 5 2020 8:11 PM
Great news - thanks for letting us know, and well done for fixing! Smile
Page 1 of 1 (5 items) | RSS
