Hi i'm Martin,
i'm new in the forum.
i own a white Beomaster 2000.
this is the product i am talking about.
and this are the lights with the broken bulbs
i have a problem finding spare parts!
the lightbulb for the power stereo and so on are broken and i would like to replace them.
the problem is i cant find any information on the bulb or in the manual about them.
so please could someone tell me witch is the correct bulb and mayby wher to get them.
thank you
martin
mr. Mexico can tell you exactly where you can buy them!
Brengen & Ophalen
Leslie: mr. Mexico can tell you exactly where you can buy them!
The Dealer Leslie has at least 5 of these, but if you want to be sure to get the right ones mail Dillen (Martin) on the forum
Søren Mexico:if you want to be sure to get the right ones mail Dillen (Martin) on the forum
Seconded. The circuit is a bit silly and will only work properly when all the bulbs have the right ratings. Replace them all while you're at it, the still working ones might fail any time and the receiver is a bit annoying to reassemble (you'll know when you try to get the cover parts to line up properly...).
This is a very nice receiver!
--mika
Søren Mexico: Leslie: mr. Mexico can tell you exactly where you can buy them! The Dealer Leslie has at least 5 of these, but if you want to be sure to get the right ones mail Dillen (Martin) on the forum
