Right now I have an BL8000 connected to a Core. This works great for music but now I want them to use for my TV audio too and is it possible to make a 5.1 setup with another pair of BL8000 and other?
Thanks in advance!
Hiddecollee: Right now I have an BL8000 connected to a Core. This works great for music but now I want them to use for my TV audio too and is it possible to make a 5.1 setup with another pair of BL8000 and other? Thanks in advance!
I am sure, that you - with 5.1 - mean a speaker setup consisting of front, center, subwoofer and surround channels.
For this you’ll need some kind of multi channel processing - as you find that in common A/V receivers or already built-in to the Bang & Olufsen tv’s.
You can not make that happen with just the BS Core alone - however, you can integrate the BS Core with the newer B&O-tv and choose the front speakers (e.g. your BL8000) there as the speakers for only-audio/music.
I did answer, but my post went into moderation - for whatever reason ;-(
Please be patient....or maybe someone else will answer your question.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I can see this comment though! Would love to see your answer :)
