Beolabs 8000
gruane
Posts 2
gruane Posted: Fri, Jan 3 2020 11:45 AM
Ive recently bought a pair of 8000s but I have an issue with one of the speakers going into standby for no reason. There is no set time it happens, but it often happens after 1+ hours.
Im using the RCA connection, have tried different cables and sources. I was considering buying a Beolab Receiver 1 to connect using the powerlink connection instead.
Does anybody have any insight on what the issue might be?
Gary
StUrrock
Posts 995
StUrrock replied on Fri, Jan 3 2020 12:27 PM
Maybe a dry joint on the back of the rca input of the BeoLab.
Rather than the wireless transmitter, why not try one of these;
https://almando.com/index.php/almando-powerlink-switch-stereo.html
gruane
Posts 2
gruane replied on Fri, Jan 3 2020 2:20 PM
Thanks for the tip!
That switch looks a bit expensive. My TV is WISA enabled, I was planning on going this route anyway so purchasing the Receiver 1 suits me better :)
I might try a  3.5 / RCA to powerlink cable if I can find one. Dont have the money for the Receiver 1 atm. Expensive XMas!!
Cheers
Page 1 of 1 (3 items) | RSS
