BeoCenter 9000 cassette/tape head stuck in play position
bc9000
Posts 2
bc9000 Posted: Sat, Jan 4 2020 9:14 AM
Hello,
I am looking for help: the cassette/tape head is stuck in play position and will not retract back to stop position.
Is there any button combination, etc. to force the playhead to return to stop position?
I would rather find an elegant solution instead of breaking the old 1984 cassette into pieces an probably getting debris into the mechanism.
All the help is appreciated!
Cheers,
Timo
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jan 4 2020 11:05 AM
Most likely this happened because the belt is slipping (or the belt was wrong and the motor bearings now destroyed).
Rotate the flywheels in the normal playback directions until the tapehead bridge retracts.
I can supply correct belts for this tapedeck.
bc9000
Posts 2
bc9000 replied on Sat, Jan 4 2020 7:39 PM
Hello Martin,
do you mean by the flywheel the pin and disc (number 4) in the following image: https://www.researchgate.net/figure/Cassette-deck-1-PM-motor-2-capstan-3-belt-4-flywheel-5-pressure-roller_fig9_244989418
And would the normal direction be counter-clockwise?
Yours truly,
Timo
Page 1 of 1 (3 items) | RSS
