Hi all, my BV Eclipse was totally fine, but today the green light in the front starts to flash green and a have no sound and no picture. I can see the BV Eclipse over spotify but nothing happens ;(
Can someone help me please?
Yes, I already try to disconnect the whole system from the power more then 15 min. The strange thing is, that I can see the system in the app, but I can’t get any pictures or sound
Same yesterday with my eclipse, but i left the house, so i didn‘t care much about it. Today the tv was working as always.
cheers
Thank you for your feedback! I try the same , but today the eclipse doesn’t work.
any idea what else I can try?
Thank you, I checked all connections but it seems like everything is ok with the cable and the connection.
Lapet:Thank you, I checked all connections but it seems like everything is ok with the cable and the connection.
Have you try change battery in BeoRemote one, Reset your remote control and pair it to the soundcenter again, with the button on the right side?
Could work:)
Or, try to start the tv with the app, or if you have a apple tv, try it via the apple remote.
It isn't trying to update its software?
Then just wait and don't interrupt.
Thank you for your help!
I tried the Apple remote but it doesn’t work
I tried to reconnect the beo one, but it can’t reconnect
The eclipse runs the whole night with no changes
i checked all connections but not the 2 cable under the tv ( to risky)
I can connect Spotify over chromecast. I see all informations in the app, but the tv is totally dead (no picture and no sound)
I opened a ticket and hope that b&o can support me. I will send a update.
Hi, How did you fix the problem? I'm having same problem
Thank you for sharing
yesterday the B&O Service had change the DSI board from the Eclipse and a something from the LG
Thanks you quick reply. Did they start by give you any guidance on how to fix the problem your self, which I could try?
No, it was very clear. They told me to contact the service partner
My unit has began this symptom overnight and I also had a battery low warning on my BeoRemote 1.
Any update to whether this is an issue that can be resolved without calling out service?
How you describe it is accurate, no sources on Beoremote and nothing from the television other than a fast blinking light which is continual.
