I have just ordered a Stage and am thinking about the positioning.
I have my TV wall mounted fairly low on the wall (top of the TV is eye line when seated ~110cm) and positioning the Stage above the TV will put it closer in line with my ears than below the TV.
However, given that the Stage has upward firing tweeters is this a concern?
I'm worried that mounting it under the TV will make it too low.
Any thoughts on this? Has anyone mounted their Stage above the TV?
I must admit rhat the tv is rather low mounted - however, I would still think that the best position will be below the tv.
Have you considered placing the Stage on a board below the tv - it might look better?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Well sad to say that after living with the Stage for a while I've decided to return it.
I found the sound far too boomy for my ears and also the stereo separation was too much of a compromise compared to my existing setup. Funnily enough I found the best sound to be when it was positioned against the wall but set to table mode in the settings.
In the end though I found the sound of my 30 year old B&O to be more pleasing to my ears than the Stage and so couldn't justify the money I'd spent on it.
Maybe I should go for the Beolab 3 instead?
Off topic: but why would you want the stage soundbar AND beolab 18?
