Hi everyone,
Unbelievably basic question I'm looking for help on - please be kind!
I've inherited a Beovision 7 TV Model 9334, item 1817831, serial 20239266.
It came with 2 massive soundbars and 2 remote controls.
All I want to do is try it out, check if it works, then decide what to do with it.
I believe it was all working before it was re homed with me.
I can't find any user guides on the web, and the paper ones that came with it are long gone.
I've plugged mains in (figure of 8 cable) and tried to operate with the remote control, but nothing is happening.
There are no lights on anywhere and no sign of an on/off switch (there's a silver oval thing underneath the front edge that doesn't seem to move).
Am I missing something stupid I need to do, just to fire it up?
Many thanks
Thanks I've found the instructions online now. I'm almost too embarrassed to say what the problem was. There was a bunch of mains cables taped together and I'd plugged the cable used as a power extension into the TV, not the one from th mains plug. It was dark and I was tired......
