Yesterday I uploaded a new software for my Beolab 50 (2.3.4.7045). The last software was 2.3.4.6892.
I wonder if this is the "fix" for randomly loosing contact between slave and master speaker (fast flashing orange master speaker).
Best RegardsMartin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Probably means the BL90 is updated to?
Anyone confirm.
need to get home soon
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Works fine for me. I’m on 2.3.4.7045 firmware for my Beolab 50
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
yes, both should be the same and as far as I am aware the SW number should also be the same for the 90's.
Confirm the update number.
Im not sure what has changed? Tone controls were added some whole back so?..
Geoff Martins website has quietly removed the BL90 feature list so the few remaining elements (PL and USB volume control) I.e the two most useful features I would like appear to be dropped??
Can anyone else confirm Implementation or not?
Mr 10Percent:Confirm the update number. Im not sure what has changed? Tone controls were added some whole back so?.. Geoff Martins website has quietly removed the BL90 feature list so the few remaining elements (PL and USB volume control) I.e the two most useful features I would like appear to be dropped?? Can anyone else confirm Implementation or not?
- Flere
smile and enjoy the moment
Is there a section on the B&O website where I can check the change history and the current firmware for my Beolab 50s?
They only seem to be able to update the firmware when connected to the internet via ethernet, and they aren't connected via ethernet most of the time. It's frustrating that they can't seem to update via wifi.
Gullwing: Is there a section on the B&O website where I can check the change history and the current firmware for my Beolab 50s? They only seem to be able to update the firmware when connected to the internet via ethernet, and they aren't connected via ethernet most of the time. It's frustrating that they can't seem to update via wifi.
I also wonder this as the BeoWiser BeoLab 50 First time setup video advices the installer to update the software first time manually via USB as the master unit will NOT update the slave unit if the firmware in the slave is lower than the master. It simply assumes that the slave has the same version as the master (which of course is a horrible design fault). It seems that only B&O employees can download the firmware files as it is on an internal network page. I wonder if anyone here has the firmware available for the BeoLab 50s so I can update mine over USB when I receive them in a few days. As I have decided to do installation myself. I also read that a few people here have different version on their respective speaker sets and that means this is an issue. Perhaps B&O has resolved it though in later iterations of the firmware so that the master does actually take into account a version conflict. But I do not know.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:I also wonder this as the BeoWiser BeoLab 50 First time setup video advices the installer to update the software first time manually via USB as the master unit will NOT update the slave unit if the firmware in the slave is lower than the master. It simply assumes that the slave has the same version as the master (which of course is a horrible design fault). It seems that only B&O employees can download the firmware files as it is on an internal network page. I wonder if anyone here has the firmware available for the BeoLab 50s so I can update mine over USB when I receive them in a few days. As I have decided to do installation myself. I also read that a few people here have different version on their respective speaker sets and that means this is an issue. Perhaps B&O has resolved it though in later iterations of the firmware so that the master does actually take into account a version conflict. But I do not know.
Aussie Michael:Um. What BL50s are coming in a few days ??
Mikipidia:2.3.4.7045 is the lastest, guessing it’s a type-o? New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube (finally ) https://www.youtube.com/c/Mikipedia Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Are they wired or wifi? Wired will fix it, if wifi then I always had to double tap them to make the app work. But with eclipse or harmony it can also be done in the the speaker settings of the tv's menu, don't know about earlier tvs.
Razlaw:I have never noticed anything like that
Not sure what it might have been. Maybe just AirPlay or Apple TV issues. Or something else. As I could not access the app or the webpage maybe something had been causing this. I restarted them today and listened for an hour and it seems to be OK now but time will tell. Have you ever had any issues with your speakers so you have to turn them off and on again by pulling the cable or something?And, by the way. Did any of you get a microphone with the speaker? In the Beolab 50 introduction to features video, Geoff says at 6.50 that a microphone is included.
I have to return my first pair of speakers after 3 month because they lost contact between the speakers 3-4 times every week. When they lost contact, the masterspeaker started to flash orange very fast.
After this first pair of speakers, I got a new pair that works rather good. I just have had this problem (loosing contact between the speakers) a couple of times in 12 month. So yes, the new pair was alot better than the old pair (same software in both pairs!!!).
What You describe that you sometimes loose sound for a short while in one speaker: I have experienced this some times but it happens just for some seconds and then both works as they should.
Your problem with the app looses contact with speakers: I have also experienced this a couple of times, and you need to restart (pull the plug of and on again) them again to get the app work with the speakers. As Raslaw said: there is a bug that make this problem happen when you use the app to change beamcontrol (from wide to narrow or vice versa).
Conclusion: This speakers is not working 100% everytime, and some *** happens from time to time. But they work perfect at 98% of the time.
SWEDEN
Razlaw:I have had one problem with the app that requires them to be restarted. If using the beam control adjustment to change settings within a specific listening mode while listening to music, such as distance or wide/narrow, the app has frozen requiring them to be unplugged. I have not experienced it recently, although I rarely use that feature. I believe it may have been, or will be corrected, in an app update. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Martin:Hi, I have to return my first pair of speakers after 3 month because they lost contact between the speakers 3-4 times every week. When they lost contact, the masterspeaker started to flash orange very fast. After this first pair of speakers, I got a new pair that works rather good. I just have had this problem (loosing contact between the speakers) a couple of times in 12 month. So yes, the new pair was alot better than the old pair (same software in both pairs!!!). What You describe that you sometimes loose sound for a short while in one speaker: I have experienced this some times but it happens just for some seconds and then both works as they should. Your problem with the app looses contact with speakers: I have also experienced this a couple of times, and you need to restart (pull the plug of and on again) them again to get the app work with the speakers. As Raslaw said: there is a bug that make this problem happen when you use the app to change beamcontrol (from wide to narrow or vice versa). Conclusion: This speakers is not working 100% everytime, and some *** happens from time to time. But they work perfect at 98% of the time. Best Regards Martin SWEDEN Beovision Eclipse 65 with floorstand (from STB Brackets), New! Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K. AURALIC Aries G1 (new)
Martin: Hi, I have to return my first pair of speakers after 3 month because they lost contact between the speakers 3-4 times every week. When they lost contact, the masterspeaker started to flash orange very fast. After this first pair of speakers, I got a new pair that works rather good. I just have had this problem (loosing contact between the speakers) a couple of times in 12 month. So yes, the new pair was alot better than the old pair (same software in both pairs!!!). What You describe that you sometimes loose sound for a short while in one speaker: I have experienced this some times but it happens just for some seconds and then both works as they should. Your problem with the app looses contact with speakers: I have also experienced this a couple of times, and you need to restart (pull the plug of and on again) them again to get the app work with the speakers. As Raslaw said: there is a bug that make this problem happen when you use the app to change beamcontrol (from wide to narrow or vice versa). Conclusion: This speakers is not working 100% everytime, and some *** happens from time to time. But they work perfect at 98% of the time. Best RegardsMartin SWEDEN
Hello again Martin,I read today in the install manual for Beolab 90 that I got from a fellow here on Beoworld something that might be the cause for the issue we are seeing with audio drop out. I quote: Notice that any infrastructure components as Ethernet switches etc. used in the DPL link needs to be AVB compliant. Otherwise the Beolab 90 Ethernet interface will switch to a Best Effort mode, which can cause audio dropout, timing and power up/down issues. Im not sure if this means that problems might occur if the speakers are connected specifically through an external switch and not by a cable between the two or if it means that it might happen if a switch is just connected to one of the ports (for example for internet connectivity and app management). It is possible to set the speakers to use the best quality mode (dont remember what it is called, but it is not best effort) instead of automatic or best effort. I will try that and see if forcing that is causing dropouts or if it is better with best effort. It might be that the speakers need to be wifi connected to have this issue removed if the case is that using a consumer switch/router cabled to Beolab 50/90 might cause issues. This might also have been fixed in later firmwares but as I experienced drop outs the first day I am not so sure.
Mikipidia:Just to be clear, they’re wired for internet and sound?
Yes correct.
Cat7 straight between speaker slave and master DPL ports.Cat7 straight between speaker master PL and Avant 55 PL port. Cat6 cable to ethernet from the DPL/Ethernet port on master to wall outlet - to media center - to router. (for internet, software update/app control).
Mikipidia:That’s all good then because i can only occasionally emmulate your app problems when I switch the speakers to wife for app control, but other than that mine are problem free on wired internet. Not that it should matter, but is the cable between the speakers in the same hole out of 3 on either side? And is it an uninterupted cable? Or do you use wall plugs or any kind of extension? Maybe silly question, but have you tried WiSa and do you have the same drop out issues in WiSa mode? New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube (finally ) https://www.youtube.com/c/Mikipedia Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Michael: - the speakers turn off immediately with it’s slow turn off due to the speaker tweeter moving. When I change between sound modes I would prefer a delay of a few seconds if I chose the wrong one by accident.
Razlaw:Could you clarify what your concern is about changing sound modes? On mine, if I change modes there is no movement of the tweeter at all, unless the mode change requires a change between open and wide, in which case that change occurs very quickly. Also, the sound gets softer very briefly as the mode changes. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
The update is only to address a loud unexpected popping noise which can appear on the secondary speaker every once in a while. A very intermittent problem. No other bugs/fixes are introduced at this time.
Ah, you know... A little B&O here, a little there
BeoMegaMan:The update is only to address a loud unexpected popping noise which can appear on the secondary speaker every once in a while. A very intermittent problem. No other bugs/fixes are introduced at this time. Ah, you know... A little B&O here, a little there
